Got the car serviced the other day - mechanic ran some diagnostics (not mercedes)
I think the Door Front left are because i had to replace the wing mirror housing as the LED died
Should i be worried about the Engine codes?
thanks
Engine Codes
22E0 - No vehicle speed signal Read out fault memory of control unit N47 - 5 (ESP & BSP control unit)
2373 - Adjustment of injector injection quantities Range 2
Door Front Left Codes
9909 - The Output for actuator motor "additional door lock" has a malfunction. There is an open circuit
973D - The Output for the Turn Signal Lamp in the outside mirror has a malfunction. There is an open circuit
thanks
