I've just bought a new nissens radiator for £81 from eBay from carpartsandspares2012 this company is based in BirminghamTwistedmind said:Are the hoses a mb direct part ?? Sent from my iPhone using MBClub UK
May have been caused by a protective coating or manufacturing residue on the inside of the new radiator. Always an idea to give them a flush through before fitting. However unlikely to be a problem unless its extensive- If it worries you - drain but keep the radiator coolant =[to inspect ] to judge the extent of the problem. If its just a surface scum just remove it refill and top up. If it's extensive you might want to consider reflushing the system and using a new coolant mix.All work is now complete. But a few problems
Esp fault on dash. I have fully locked the car steering left and right (normally sorts it) but no joy
And there looks like I have a white substance in the rad water. Looks like white spunk lol.
Not sure if the anti freeze has caused this
Hey Bonkkis - This old post showing imageshack links which you say in your post lists affected cars - is that the same list contained in MB TSB P-B-27.55 50f ie W203, W209 and W211 various model numbers? Can no longer get images from your link above.below 3 lists of affected cars. the list has been verified as MB list by MB finland. however it's completeness/correctness has not. according to MB spareparts service central (and others pretty trustworhty sources) in finland there are other affected cars including those with behr radiator.
most affected cars seem to be 2002-2004.
check the sticker on your rad. if it says valeo and pre 9/2003 (however not pre 2002) there's a good chance your rad can cause the problematic leaking. then again it might not.
if your car is in the risky ones first do the glycol verification. its around 40£. just suck 1-2ml of atf with a new hose and syringe and take it to your mb dealer. if the amount is not critical changing the rad and atf CAN do the job. if critical the damage might be done already. vibration while driving is a common symptom for this kind of a problem. by then it might be too late to change just atf. you might need a new tranny.
keep in mind that if your rad has been changed, it might still have glycol in the atf. do the test anyway. a cheap insurance.
ImageShack - Best place for all of your image hosting and image sharing needs
That's because they are from 6 years ago.
If you car was going to have the issue it would have by now.
Hi, I know this is an old post, but I am looking to buy a late 2002 CLK320, which I think will have the Valeo radiator. Can you actually see if the banjo bolt grommets are in good condition and can they be replaced?There is no inherent weakness with a Valeo radiator. Valeo are a high quality brand for many items.
The issue is that the internal heat exchanger has rubber connection grommets where the ATF banjo bolts pass through the plastic radiator end cap. These grommets weren't lubricated on build so the banjo bolts deform them, sometimes allowing ATF and coolant to mix.
As long as the grommets are OK there is no issue.
Behr radiators use an identical system.
