side indicators
MAS
West Midlands
Mercedes C200
hi everyone
well while i was out about 20 mins ago my mate spotted that my side indicator (passenger) wasnt working thought ok might be a bulb got home now to check both sides dont work drivers and passnegers and bulbs are perfect so what can this be now ? because they dont work when hazards are on and nor do they work with the stalk ?
thanks MAS
Have they ever worked?
Maybe your car has had them disconnected, otherwise it must be a common feed/earth problem
You can see where they come through the inner wing, so just follow them.
Have you tried a new lamp or just looked at the originals
i never noticed since i bought it mate and now lucky me mate spotted them as mot is due soon so i need them fixed asap
can i see the wiring threw the engine bay or will i have to remove arch cover ???
i would do more than a visual check on the bulb. if you know the driver's side one works for sure, switch the bulbs round. if the driver's side doesn't work with the passenger bulb, and the passenger side does work with the driver bulb, then you'll know for sure. might save you the hassle of digging for wires etc... never hurts to try the easiest thing first!
edit: sh!t, just re-read your post, didn't realize both sides were out! check your fuses, one might have blown?
havent checked the fuses just yet because havent had much time but will do soon
