Druk
Gone but not forgotten - RIP
- May 28, 2004
- Location
- Not far from Edinburgh.
- 2011 S212 E350CDi. 1981 R107 300TurboDiesel.
About five years ago I replaced one of the roof hatches in the caravan. It's approx 300 x 300 and made from an ABS type plastic and is held to the roof by an internal frame screwed up into it on four corners. The sealant used at the time was Evo-Stik No-Nails which I've successfully used in many other applications.
This seal failed spectacularly during a nighttime thunderstorm at Coniston eek: and was temporarily repaired by a bead of silicone sealant around the edge.
This has also now failed and i have to take the hatch out to re-seal it properly.
1. What is the best sealant to use on a plastic/painted metal interface? If silicone then which one?
2. Would I be better spacing the hatch off the roof with (say) 3-4mm spacers and gunning the sealant into the gap rather than have most of it squoze out by the clamping action of the internal frame?
What say you?
What say you?
