Hi I have a year 2000 SL320 129 shape The drivers door around the check strap has split in two places .It has never been damaged before, anybody else had this problem ?. I have recently submitted a claim to MB not sure if it will be honoured
I had exactly the same on my old 99 SL320
The checkstrap is the fault, it deteriorates over time and then causes stress on the metal. I took mine to MB at York who submitted a claim which was sadly rejected on a full MB service history with 52k on the clock.
I ended up getting it welded at a bodyshop and repainted but it was fine after that.
The check straps seize up and start flexing the door as you open & close it. Often the mounting ears on the check strap that sit flush to the door shear off and the check strap body starts floating about
A graunching noise means check your check straps... I also always check the mounting bolts on the door. If they're loose I get suspicious that the check strap is seizing
