MichaelSB
I didn’t know that, I will look closerI would also try to get a facelift (sometime 04 onwards) car as it has much better command including Bluetooth and other small changes and improvements.
Wise words.Possibly, but if you're looking to buy a car you can run on a shoestring, don't buy a fifteen to twenty year old SL 55. Expensive cars tend to have high running costs, and as they get older the cars get cheaper but the running costs don't. Has the car had any preventative maintenance on the known possible problem areas? If not, well, roll the dice and see if you're lucky, but be prepared not to be...
As we all know there are no guarantees with any car so you’ll need to factor it in. If there’s no sign of maintenance on the ABC I would get a quote to replace all the accumulators and pulsation damper, plus fluid and filter change. Factor that in to the price.i have an opportunity to buy a 45k car but my hesitation is the car has has none of the usual issues with suspension etc so has it built up a few big bills
To complicate your calculations the late 2006 to 2009 SL500's were much improved.I didn’t know that, I will look closer
Can't say that that's the logical conclusion. The real damage on SL's gets done through LACK of use (and servicing). It's not moving "moving parts" for long periods of time which can create a problem, particularly if the car isn't serviced by someone who cares. (i.e. just an oil change isn't enough)i have an opportunity to buy a 45k car but my hesitation is the car has has none of the usual issues with suspension etc so has it built up a few big bills
