SL 55 intakes fitted
dredd32 said:
Sorry had it on private. Should be good now
Looks tidy that! Hmm Santa may have another thing to add to his list! I'm looking forward the the dyno results! Don't suppose you can post the part numbers can you?
MA 113 090 05 01 air cleaner. £78.00
MA 113 090 06 01 air cleaner. £78.00
MA 113 090 03 29 air intake. £131.00
MA 113 094 16 82 hose. £7.20
MA 113 094 17 82 hose. £7.20
All prices inclusive of VAT
dredd32 said:
MA 113 090 05 01 air cleaner. £78.00 MA 113 090 06 01 air cleaner. £78.00 MA 113 090 03 29 air intake. £131.00 MA 113 094 16 82 hose. £7.20 MA 113 094 17 82 hose. £7.20 All prices inclusive of VAT
Which dealer did you use?
Prices exclude VAT.Misread invoice
So been onto Jerry who says there's no reason why my car won't gain the same as others have with the SL55 mod and says the ECU should adapt ok without a map alteration so happy days!!
Does anyone know if the E55k air boxes, hoses and y pipe are the same as the SL55k's? They do have differing part numbers I believe but from over the pond I've read they are the same interchangeable items.....? And apparently cheaper.....!!
I'll believe it once it's done and dynod! My guess would be +10hp I reckon!
If that. I can't see Mercedes fitting undersize or constricted air trunking on an AMG model.
It would have been interesting to see actual pressure drop readings, before and after change.
How did the air boxes fix down onto the block elvin?
Had to take the brackets off as they don't line up..They fit well,though I've had to use a cable tie on the left intake until I adapt the clips. Looks an easy enough job..
Overall I'm very happy with the outcome..
dredd32 said:
Had to take the brackets off as they don't line up..They fit well,though I've had to use a cable tie on the left intake until I adapt the clips. Looks an easy enough job.. Overall I'm very happy with the outcome..
I'm holding fire on this until your results lol!
dredd32 said:
Dyno at1230 I'll get there a little earlier to let car cool a bit.... U fancy meeting me there do u??
God forbid it's the wife's birthday lol! Just seeing if you'd have results before the parts department closes haha!
