Ha ha very wise.
Depending on results you might want to buy your wife a new heat exchanger for her bday lol
sjmaxwell said:It'll all end in tears!! :bannana:
dredd32 said:Was approx 360 before intakes and 410 after
Yes I'm very happy with the intakes and with the extra torque they've given me....
Wheel dynos are a complete waste of money and time, that can be made to say anything required.
As said, your gains are due to ambient temperatures and maybe the original result was low for some reason.
Buy a £5 stopwatch and test ALL mods before and after using a flat road and 3 acceleration runs in each direction.
I can't see the intake making much difference as it is unlikely to have been restrictive anyway and the throttle body is probably the most restrictive part...and that hasn't changed.
Was only a matter of time before the stopwatch got mentioned
I had the car dyno'd there earlier in the yr and it ran 369hp with 365ftlbs torque. Today 378and 410torque.
Strangely when I took it to msl in June it ran371hp and 410torque before the new intake mod
And the problem with a stopwatch is?
ALL race teams use stopwatches.
As you obviously know more about tuning than me, what were the pressure drop readings on your old and new intake systems and where are the bottlenecks?
My guess says you haven't a clue.
No one said they know more about tuning than the great dieselman...I looked at the cfm of my intakes and it read 400 and 515 on the slk...I bought this item as I was told they would increase power which it has to a fashion.
The reason I try and avoid your posts is because of this. You stick to your stopwatch and I'll waste my money on dyno'd
