davrum
Ideas please anyone, having turned ignition off in middle of putting hood down, I initially had lights flashing on roll bar switch and hood switch, having made sure everything was closed down and locked I now just have the roll bar switch flashing.
Press hood switch windows go down and clicks behind seats.
Press roll; bar switch the Hydraulics pump relay clicks but no pump, have also tested relay and - ok
have tested pump independently and it works.
Have checked to see if power coming through wires to the pump and no there isnt any power coming through the wires
I believe I have checked the fuses
Have just put meter across the pump power terminals before the relay and there appears to be a small current.
No Leaks, reservoir is full
Have done usual, disconnected battery, cleared error codes, window reset.
.Would very much appreciate any thoughts anyone might have, thanks in anticipation
