Has anyone tried changing the hydraulic rams for an SL (R129) soft top themselves?
I've recently had 5 (yes 5!) of the hydraulics spring leaks and have shelled out an obscene amount of money to have them replaced. Having had only 2-3 days of roof enjoyment since then another of the hydraulic cylinders has begun to leak! I am assuming that by repressurising the system the pressure has found the weakest link (i.e. one of the other old cylinders) and caused it top leak. It is the passenger side cylinder that lifts the roof cover - the one that protrudes throught the small hole at the back of the compartment.
The car is a '92 Hong Kong import (only 49k miles on it!). I think the years in the heat and humidity (and probable lack of use of the soft top - evidenced by it's excellent condition!) have taken their toll on the hydraulics.
Any help is much appreciated.
Anybody else had these problems! Can't believe hydraulics could be so much of a problem!!!!!!
