Blucher
Hi
Hope someone can help me.
Late 1997 SL320 I6. Mileage approx 31k.
Over the past couple of weeks car has had rough idle and when D or R selected revs drop
and she cuts out.
Can take 2 or 3 turns to start.
Only seems to happen when engine is warm.
Above idle she pulls well with no problems.
I have also noted that when driving and I take my foot off the accelerator, the mpg gauge doesn't go to max
but stays about 30 mpg and revs fluctuate between c750 - 1000.
So I'm thinking the mixture is too rich.
I note from the service history that the car had some rough running in the past....
In 2016 the MAF sensor and O2 sensor were replaced on 2 separate occasions.
I've had the car 3 years without any issues.
Have cleaned MAF sensor with electrical contact spray but no improvement.
Tried disconnecting MAF but problem still there.
Checked purge valve which seems fine.
Car has had new plugs and air filter in last 1000 miles.
If I got a 38 pin adapter and obd2 reader do you think this would show anything useful ?
Any help appreciated.
I hope SLs can't catch coronavirus or can they ???
and she cuts out.
