SLJCH
Hi everyone,
I am hoping someone can put my mind at ease as after speaking to my local Mercedes dealership today I think they have got my boot operation confused with the electric motor one instead of a manual opening. After looking for 18 months I purchased my SL 350 (R231) 2013 model last February from a Mercedes dealership and within a week it had to go back as the ILS lights needed leveling as I was blinding everyone and a key replacing. Anyway long story short I got my car back last week and started to enjoy it and I love it.
I am confused though regarding the boot operation as on releasing the boot with either the remote key or button on the driver's door the boot opens about an inch and just sits above the lock not fully springing open. I replaced the boot struts a couple of days ago with the same OEM gas struts from Stabilus and the boot will still not lift on its own. On talking to Mercedes today it seems the OEM gas struts have the same eject force as the genuine part which they agreed should spring open the boot. Of course, further discussion lead to suggesting I take my car in for a diagnostic.
I was reluctant to do a diagnostic as they couldn't actually tell me what the operation should be. Like the dealership I have read various forums with no actual conclusion of what the manual operation should be, is it meant to spring up, or do what mine does and open just beyond the lock so has to be lifted by hand. To me, it seems pointless to put a release button on the remote key & driver's door if it means when you get to the actual boot you have to lift it up? Why not just use the release button on the boot lid if it isn't going to spring up? In the owner's manual, it makes it sound like you should be prepared for the boot to spring open.
Since fitting the new gas struts the soft close feature seems to work every time when I push the boot down by hand and then seems to vacuum the boot lid into the lock. If it wasn't for this action I would say the boot opening/closing is fully independent on the gas struts but I am wondering if there is something mechanical I am missing that is hindering the boot from springing up. When I removed the old struts the boot moved freely up and down by hand with the roof mechanism, and with the new struts fitted it pushes up by hand and holds in position. The roof operates as expected so at a loss and really hoping someone can enlighten me that this is either normal operation for my model or there is a fault of some sort that I have not detected.
Any input will be appreciated.
Cheers James
Cheers James
