SL400 (R231) - Does a new battery need coding?
kolobos
Scunthorpe
SL400 AMG Sport 2015
I have suspected my battery has not been the best for a while with the start-stop feature only working occasionally and then after a couple of start-stops it does not work again for days? I have just bought a 12v battery tester and it reports its health as being 15%, Charge 42% and everything else as OK. However, it does prompt me to REPLACE the battery. I am more than willing to do this and would like to know if the battery will need coding to the car? I am planning on buying the exact Mercedes replacement battery. Thanks.
Steve.
kcsun
essex uk
SL63 AMG, RS4
If you have never replaced the battery then it has done well to last 7 years. All AGM batteries have a "chip" with a unique code so it will need coding to the car. Buying the exact same battery is not enough as the chip code will be different.
Have you asked your MB dealer for a quote, I believe they always were very competitive on battery pricing. If you are not using the car as a "daily" it may also be worth investing in a trickle charger to keep it in tip top condition. If you are an MB club member you may get a discount - worth asking
kc
oldguy57
Lancashire
Now various and sundry
I've bought numerous AGM batteries over the years for our cars and other stuff, and I've never heard of any having a chip, or any kind of coding necessary. Is this specific to start stop spec cars?
whitenemesis
MB Club Veteran
Lexus RC300h F-Sport 2019
Replaced the AGM battery in my CLS and no mention of chips or coding.
Simply swapped them over and reset the windows etc.. No issues
Ted
Bourton on Dunsmore
Lexus RC300h F-Sport, Yamaha XVS 1100, Jeep Renegade
Replace luck for like = no coding
Replace for a larger capacity = coding to get the most out of the capacity of the battery.
OP
OP
K
kolobos
Scunthorpe
Thanks for your replies, I know a local independent dealer who is Mercedes trained and connected to the Mercedes computer network so I am confident he will be able to sort if I cannot. I have some Mercedes OE diagnostic kit (not STAR) which can code parts etc to cars. Not sure about Mercedes yet though, none the less I should be able to sort. Sounds as though a like for like genuine battery will be OK. Thanks again,
Steve.
  • Like
Reactions: Ted
Skd884
A handful of Amg v8s.
Never heard of a battery require coding...
Slow charge your battery for 12 hours, might be fine for years ahead.
kcsun
essex uk
SL63 AMG, RS4
Steve.
I have the icarsoft obd tester and that can code a battery
kc
geoffus
Burbage
E250 AMG Sport Convertible, B200, Yamaha YZF R1.
Changed mine recently, don't need coding and you can buy a quality battery for a lot less than Mercedes will quote you.
David44
Land of the Prince Bishops
2013 R231 SL350
Changed my original Varta battery last year with a Bosch AGM...no coding everything works fine.
I don't think AGM batteries are chipped as such but the car system needs to know the battery spec in order to calculate how much power is available.
Diesel Benz
Europe
223.168 & 213.012 & 906.633
kc
This is not a thread for Russian propaganda.
No chip on any Mercedes battery. Latest models have an option to tell the relevant control unit that the battery has been changed. Helps to gain perfect operation immediately after the battery swap. Without "reset" the car adapts rather quickly to the new battery properties, no big harm if not "coded".
OP
OP
K
kolobos
Scunthorpe
Definitely, no coding is required after speaking with the main dealer, also the battery part number has changed from A0055411001 to A0019828208 and they are £193.82 inc. vat. I will probably buy the original one as the car is totally original and genuine. Not a single part is non-genuine from new. At some point, this will change I know that :) Thanks again for your replies, much appreciated.
On another note, has anyone had the need to change the auxiliary battery behind the driver's seat?
  • Like
Reactions: Ted
OP
OP
K
kolobos
Scunthorpe
New battery swapped over in a few minutes, no settings lost, no issues or problems showing at present. All windows working as they should. ALL GOOD.
