cardiffrob
- Dec 13, 2008
I've tried the search function but not found anything.
2002 car that sometimes shows temp readings of 40 to 60c after a long run and then maybe the gauge won't even get off the bottom stop on another day. A few minutes ago it looked as if the needle was up off the stop whilst the ignition had been off for a few hours. Surely it is electrical and won't read anything whilst the ignition is dead?
If it is a sender failure then where is the little sod located?
Cheers
Cheers
