Hello, hoping to find some pearls of wisdom on this one.
I recently acquired an SL500 R230 and up until recently have had no need to use the heated rear screen. Unfortunately, I pressed the button in the car last week and although the switch lights up the rear screen heater is clearly not doing anything at all.
I've checked the related fuses under the bonnet and also the one in the glovebox behind the drivers seat and both are fine. I've also checked the associated relay and that is also fine....GULP!!
Has anyone had a similar issue? I've tried searching for threads on this but there doesn't seem to be a conclusive answer....that I can find. Perhaps there is a way of testing the heating element in the screen itself? I really don't want to replace the back window so I'm praying for a miracle here. All connections to the element look to be in order too.
