WantSL55
Press release for the SL55 performance package
SL 55 AMG with Performance Package:
Based on the official FIA Safety Car from the 2002 Formula 1 season
June 11, 2003
The SL 55 AMG with the Performance Package owes its enhanced dynamic characteristics to an extensive range of revisions to its body, engine cooling system, brakes and suspension. The design of the striking front apron, which dominates the nose of the vehicle, recalls the look of the Formula 1 Safety Car. Larger cooling-air intakes and an additional engine-oil cooler ensure that the AMG V8 supercharged powerplant - whose peak power and torque levels are unchanged at 368 kW/500 hp and 700 newton metres respectively - is maintained at the optimum operating temperatures during sporty driving.
Brake system and chassis setup from the Formula 1 Safety Car
For optimum braking performance, sensitivity and resistance to fading, the front wheels of the SL 55 AMG with the Performance Package are equipped with a composite steel brake system. Measuring 380 mm in diameter (as opposed to 360 mm in the standard version), the internally ventilated and perforated grey cast-iron discs feature floating caliper and have a greater thermal capability. All the dynamic handling systems associated with the electrohydraulic Sensotronic Brake Control (SBC) system have been optimized for the new brake system. Together, all these measures borrowed directly from the Formula 1 Safety Car deliver reliable stopping power at all times - even under the extreme conditions encountered when braking from racing speeds.
The SL 55 AMG with the Performance Package also draws on its Formula 1 counterpart when it comes to the chassis setup and the choice of wheels and tires The Mercedes-AMG engineers based the configuration on the setup used by official FIA Safety Car driver Bernd Mayländer on all the F1 Grand Prix circuits. New spring struts with firmer spring and damper settings for the Active Body Control (ABC) system provide an even more direct and responsive driving experience. Impressive looks and superb engineering come together in the multi-piece 19-inch AMG twin-spoke wheels. 255/35 ZR 19 tires are fitted to the 8.5 x 19-inch front wheels while the 9.5 x 19-inch rear wheels are equipped with 285/30 ZR 19 tires
June 11, 2003
- Striking front apron with additional oil cooler
- Sporty AMG chassis with Active Body Control
- Multi-piece 19-inch AMG twin-spoke wheels with mixed tires
