Alex - thanks. Not sure what you mean by 'split system'. I don't think I have. The OEM pump was replaced by this (done by a MB Indy last month):
https://www.amazon.co.uk/dp/B00W22IIEE/?tag=amazon0e9db-21
But much cheaper price (£108+vat).
I had a fan problem on one of my diesel 211s, and the message "Check Coolant Level" came up; that is the message you get if there is a problem with the fans - there is no "Radiator Fans Faulty" message in the OBD.
The problem is with your radiator cooling fans. Serviceable fans run up to a fairly high speed and stay there until the coolant temperature drops. They do not slow down after a second or two, and they do not make rubbing noises.
