Tylerhayles1
So where do i start basically curious
for those are a familiar and are tyre and wheel freaks, there is something known as rolling radius etc
The sl55 comes stock with
Front 255/40/18
Rear 285/35/18
some may have experienced some may have not that if you mess around with tyre ratios/profiles to much and dont keep within a certain limit you car can even go in limp mode and experience esp and transmission problems ( yes i done this with 35R on front and 40R on rear)
i always liked the idea of meatier tyres but has to be done in certain ways,
now i was going to do a suspension overhaul accumulators, valve block etc because im not to happy with my ride at the moment,
But now also looking into wheels and tyres more im concerned my set up also may be causint problems, ride quality, handling and even potentially transmission and power problems because of how the sensors relay for information.
so here goes
I have
255/40/19
275/40/19
now learning abot tyre ratios etc i have realised how ****** stupid this set up is and what it could potentially be doing to my car despite how good it looks
to think that if you car can go into limp mode with a bad set up, can a still bad set up but not as bad that it dont throw up codes, can it still be restricting your car without you knowing, my quest is could my set up actually be causing problems
Be nice to hear from experts or people who have actually dealt with this stuff
After checking ratio calculators
Im set on.
255/35/19 or 265/35/19
rear 295/30/19 or 285/30/19
