SL55 Engine Cooling Fan
karozza
MALTA
SL55 AMG/C180 K
My radiator cooling fan seems to have decided it needs a vacation & only works when it feels like, which is quite rare nowadays
Being hands on & ready to tear it apart; was wondering if this is repairable rather than replaceable, hopefully saving a small fortune!?
Have stripped it down as concluded the controller module is at fault, as is usually the case.
Was wondering if anyone has a defective controller module lying around & not needed? If successful will share the info as presently, the only solution is to replace the whole fan assembly.
It might be of use; can you check the part number on the module?
885 000 764
It should be a TEMIC 850W
brucemillar
Next Door to Alice - 25 'kin years now
C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
I had this happen on my W203. I ended up (as you have) diagnosing to the fan controller). Water ingress had toasted some components. I bought a second hand unit from Dronsfield’s in the UK. THIS WAS A COMPLETE FAN, shroud & controller.
That fixed it.
