Sl60 electric fans do not come on !
The cooling fans will not come on once engine heated up ! And ideas on fault finding ? Have changed fan switch , works when hard wired
Are you sure they are engine cooling fans? and not A/C fans? Is the A/C system operating ok?
Is the car overheating? As mentioned the main cooling for the engine comes from the viscous fan coupling, not the electric fans...they are auxilliary / AC I believe.
Hi bleazy what colour and age is your sl60
I've just acquired an azurite blue Pre face lift
renault12ts said:
Is it also overheating?
mines silver and giving me headache lol
1. Check waterpump.
2. Check viscous fan coupling
3. Check thermostat.
Will be one of the above. As mentioned the electric fans are auxiliary to the main engine fan on the viscous coupling.
Good luck!
