moakesr
It's not that scary really, the ADS was faulty on my car, and I repaired it
If you are prepared to read, scrounge on ebay, have patience with a spanner and have good diagnostic skills then ADS isn't that bad.
The real fears are ECU and main ADS valve, everything else is not too bad, but the valve is made of unobtainium and costs thousands from a dealer, mind you one went for £80 on ebay a couple of weeks back
The ECU was superceded, and if you have to fit the later type, then you need wiring loom adapters and different switches, so that comes a bit keen too.
Not sure about the 600, but my 500 will get converted to conventional suspension when the repair bills exceed my tolerance levels, but ask anyone with an ADS or ABC equipped car, when the system works, you can't beat how it feels and handles round the corners.
Richard
Richard
Speaking of the ADS, does anyone know what the real fears with this system are? What generally goes wrong and why is it so expensive (or perceived to be) to repair? Is it expensive parts or high labour costs?
Will
