Slight steering!?
karozza
MALTA
SL55 AMG/C180 K
So, had my after market 19s powder coated black, balanced in the process & wrapped in new Potenza RE050As. Well actually driver's side are new as a whole set were fitted a few thousand miles ago & must have hit something as the driver side front & rear tyre sidewalls ballooned.
Anyways, went on a road trip & have a slight vibration in the steering which is constant above 50 mph & only goes away when I go back down to 40-50 mph.
Any suggestions?
wu56Shoozz said:
Have you tried going faster.. say up to 75mph and keeping an eye on the shudder? if you can drive through it then it may be a buckle and need rebalancing..
Yes, the issue is anything above 50mph.....60, 70, 80 etc....constant slight vibration in steering.
