chrisslk
Living in Gloucester has meant we have seen alot of rain recently and as such saw me being stuck in work for a 24 hour period. When i got into the car the following morning, she started fine but ran very rough (as though misfiring or missing one cylinder?). Thinking perhaps some water had got into the engine bay, i did as quick a check as i could to find any possible loose leads or signs of water damage. Now bearing in mind the car was driven into work fine and i didnt go through any large puddles and the water did not go past the rim of the tyres, i cant see how this could have had an effect. That said, after turning the engine off for a while i came back to start her again and she is fine. Only problem is the red check engine light is on ??? Now does this mean an expensive drive to the local stealership? or is it possible to reset the light?
Many thanks.
Many thanks.
