fluffytigra
Hi
Found the passenger side carpet soaking & found the problem leads back to the air-con filter being blocked/clogged up with debris. So need to replace that.
Could you recommend somewhere for parts please?
Also, there was a tube/pipe leading from the filter & just pointed downwards towards the 'wet' area. But the tube/pipe seemed to be too short, because if it was longer it could then be directed away from this area.
What does anyone think?
Sorry for waffling but cant explain it any other way...
