Slk "judder" from rest
paul243
slk 320
Hi
SLK 320 2002 35.000 miles Auto
I have a "judder" which seems to come from somewhere in the drive train.
It only happens for a few seconds when accelerating away from rest steadily,not slowly but not foot to the floor!, and then disappears. Gear changes seem ok.
Any thoughts?
AMGeed
Hardcore MB Enthusiast
Bournemouth/Poole Dorset
2014 E63 Biturbo
If it hasn't been done yet, an ATF change is due at 37k miles.
It might be an idea to see if you still have the "judder" after the fluid change
Do you have a decent MB indy nearby who you can do the change for you? Should be in the region of £180/£200 inc ATF and new filter.
OP
OP
P
paul243
slk 320
Thanks for that, I thought it might be gearbox related.
Is it something I could trust to my local guy who services the car?
OP
OP
P
paul243
slk 320
Ps
I have had a very slight leak of a light fluid, which is not oil, for some time.
Maybe short of fluid?
AMGeed
2014 E63 Biturbo
Ps
Low fluid is a possibility. If you trust your guy to change the ATF then go ahead.
If he isn't familiar with the 722.6 MB autobox then find a good MB indy.
Where are you located so maybe someone can suggest somewhere nearby?
OP
OP
P
paul243
slk 320
Wilmslow,Cheshire
Erfan
Maidenhead
W210 E300 TD
Loose exhaust clamps ...can give a judder type noise as I found out recently.
OP
OP
P
paul243
slk 320
Thanks to all, I'll try Nick Webster and report the result.
Trickythemerc
South Manchester
CLK 220 CDI Sport 2009
Nick Webster in Poynton is the man to talk with.
One of the best in the job, he worked for me 30 years back.
OP
OP
P
paul243
slk 320
Update:
Been to Nick Webster, instantly diagnosed as a worn "plumber block" on the propshaft.
Booked in for replacement and tracking.
He test drove it, put it on the ramp and checked everything underneath,no charge.
What a great find!
Thanks All
OP
OP
P
paul243
slk 320
Glad to hear the problem has been diagnosed correctly Paul.
ATF change next service then:D
Yes and I know where to go for servicing now!
Also found a slight play in a front wheel bearing and will do front and rear tracking for £50
My local guy said "can't find anything wrong"
:bannana:
