Slk r171 top of windscreen trim peeling
Discussion in 'Bodywork' started by tonystalloney, Jul 5, 2019.
  1. tonystalloney
    tonystalloney Member
    38
    May 27, 2015
    london
    Car:
    slk280
    Greets
    Am having the black trim above my windscreen repainted as it started to flake revealing the metal underneath.
    Has anyone else had this issue ?
    Am having it sprayed along with some other bits, not sure if respraying will cure this problem
  2. zipdip
    zipdip Hardcore MB Enthusiast
    2,630
    Mar 5, 2015
    Essex
    Car:
    s320
    I have not seen that before,so the strip of metal in your case black that is part of the top of the windscreen surround is peeling off, is it right down to the metal or base coat.
  3. OP
    OP
    tonystalloney
    38
    May 27, 2015
    london
    Car:
    slk280
    Yep, it started flaking then basically underneath the black top layer is metal underneath. It looks metal anyway could be plastic, its the trim about 1cm in.width. My sprayer seems to think its been sprayed before.
  4. Beaky59
    Beaky59 Member
    51
    Nov 24, 2019
    London
    Car:
    2005 SLK 350, Modified 1986 911 Carrera, 987 Boxster S, Suzuki Vitara (family hack!)
    Bump,
    I noticed my trim is also beginning to peel, as I believe these are relatively inexpensive, I'd like to replace it myself but does anyone know how they are removed?
Share This Page
