billhudson
- Aug 31, 2013
- slk 230
I recently bought my wife a 1999 SLK 230 K. Excellent condition with 90 K on it. As is the way of things the electric roof has been used quite a bit with no problems - until last week when it stuck (luckily in the roof up position). First thing I checked was the fluid level, which turned out to be below the minimum mark. After some research and much swearing I obtained the correct fluid and managed to top up the fluid. Unfortunately no luck there. When the switch is pushed forward to close the roof you can hear the pump operating (obviously nothing happens as the roof is already in position). When the switch is pushed back all is silent. The switch flashes correctly (or at least as it did before). I unplugged the relay switch on the side of the pump and that silenced the unit completely - suggesting that that relay is at least responsible for closing the roof. My question is - is there a second relay for the reverse operation and if so where is it located?
Any thoughts, suggestions or observations would be much appreciated - Many thanks.
