Does anyone have any advice they could give me.
I have a 2005 SLK350 which has started to throw up a "secondary air injection" alarm (P0410).
This only happens when started from cold, if code is reset it does not come back (engine warning light) until the car has been started a couple of time from cold.
Have replaced the the air pump relay and switch over valve, as these were the cheapest components.
Still got the alarm.
Removed the air pump and both diverter valves, all looked ok, nothing came out of the pump (water/debris). Valves looked clean internally on the pump side and can here them close if vacumn is applied and released.
With parts back on the engine pump can be heard to run for approx 30 sec when started from cold.
Local garage has done a leak test on the engine, checked the pump and switch over valve say they are ok.
Also checked the 4 exhaust sensors (o2) and say they are also ok.
They suggest taking to main dealer to see if there is a software update for the engine ECU if not the ECU is faulty ?????
Does anyone have any experience of this fault or suggestions as to what to check next before it goes into MB.
Any help appreciated.
