BenzedUP
Well I wanted to release some more V8 noise without having to remove the CATs, so after a quick online searches I decided to go for a simple resonator delete however I wasn't sure weather to go for an X pipe or H pipe.
Again I did a quick online search and found for the SLK55, the X design is more efficient even though the H will sound better (louder) more like a 60s muscle car, the X will sound quitter in comparison but likely to keep the back pressure and gain some top end HP.
So I went to Olly @ PCS for a custom made X pipe.
Anyway I can't be bothered to right a long essay so I'll let some pictures/videos do the talking.
Before:
After:
Quality check video:
http://youtu.be/tN_jj8DJzlU
As expected from the PCS boys & Olly, the quality & attention to detail is top notch, can't fault anything, kept me updated from the moment I left the car with them.
Sound check:
http://youtu.be/1jiZxxVRx9g
Drive by:
http://youtu.be/7JePiW0YnXw
Interior sound:
http://youtu.be/lB6eUjCM5pE
If anyone is thinking of the same then I'd say go for it, you'll never look back, you probably enjoy the sound of a H pipe a bit more but whatever you decide you'll be happy with the end results.
Thanks,
Joe.
Before:
After:
Sound check:
Drive by:
Interior sound:
Thanks,
Joe.
