television
Hardcore MB Enthusiast
Just had a 05 SLK55 round and the guy does not like the handbrake, the first three or four notched do nothing, you can feel them and it only locks on the fifth, is that the way it should be
That sounds about right.
Max 5-7 clicks.
R230s have footbrakes don't they?
Max 5-7 clicks.
I was reading a "max 5 notches" figure from the SLK docs? But adjusting should not be based on the clicks but by the adjust wheel teeth (first tighten fully and then release 10 teeth steps.
I never use the "foot/hand brake"...just stick it in park...something I picked up in USA in cold winters and have never changed ...... should I?
Fine on a flat surface - any kind of gradient and I wouldn't if I were you. The locking pin isn't designed to be particularly load-bearing.
This isn't direceted at you stats, but there is a common misconception that the Park lock is a pin. It isn't it's a chunky pawl and will hold the car on all gradients.
IF the gradient was too steep the pawl would jump due to the design of the teeth it engages with.
I've never found a gradient that the pawl doesn't hold on, although if parked on a steep gradient I generally apply the brake as well just for surety.
Are you not thinking of the mechanism of the R/P solenoid which is different?
Releasing it always feels like letting go of a tight elastic band. TWANG.
