Hi
I seem to have got a steering wheel wobble at higher speeds (motorway speed)its not a major wobble more of a vibration on the steering wheel.I have checked tyre pressures they are ok.Any ideas
Jack up each wheel and use a finger as a datum point spin the wheel and look to see if tyre is out of round, dont do this from cold do it after a short trip.
If okay get them balanced.
Hi
If the wobble is felt on the steering wheel then it's probably the front wheels that need balancing, if the wobble is felt in the seat then it's probably the rear wheels that needs balancing or an front or rear tyre is miss shaped i.e. not round.
