I would be concerned about the wind resistance on the roof structure when opening the roof at "upto 60kph", the boot lid would surely be under a lot of stress at that speed.
Agreed asking for trouble which is why common sense should prevail...I would be concerned about the wind resistance on the roof structure when opening the roof at "upto 60kph", the boot lid would surely be under a lot of stress at that speed.
The only struggle I had was getting the carpet out, in the end I just removed most of it and bent it up out of the way enough to get the connectors out, bit of a faff but it did the job.Mine has just arrived. Will install it tomorrow.!View attachment 86954
Just a quick off topic ask.... if any of you have car play available how do you change the balance/equaliser settings when the phone is connected? All I can do is change volume!! Thx..
Yes me as well. After removing the screws and two plastic clips I pulled it towards the back of the car and bent it out of the way too,,
I also routed the USB lead so it just pikes out just under the light, however it seems like its not needed unless theres an update as all the settings are available from the in car Audio menu.
Did your SL not do the seat exit/entry thing before you fitted the Smart Top? My 2004 SL does.
