Comma air con cleaner, everyone uses it
Comma Aircon Cleaner from Halfords Price £11.73 Free Comma Air Con Cleaner When You Buy Measure and Charge Air Con Top-Up
Follow the instructions carefully for best results
Tell me-All you people with smelly AC-do you run it for long periods or all the time in recirculating mode? If you do there is your problem. The theory (and the book) says your AC will be cooler and more efficient in recirc mode as it is cooling already partially cooled air on recirculating mode, but all you are doing is recirculating stale air. AC also removes the mositure from the air. A lot of us turn on our AC when we are hot and sweaty. Sweat=mositure=removed by AC system. This 'sweat/moisture' then recirculates in the system and a build up of moisture within the AC system is an ideal breeding place for smelly bacteria. Shockingly, what you are really smelling is yourself. The AC specialist whom I dealt with yesterday said to use some of that spray then run your AC everytime you use your car for a month and do not use recirc unless vital (ie: manky old ford burning oil in front of you) Surprisingly, what a lot of people do not realise is that AC can be used in the winter even with the heaters on. In fact it is a good idea to do this to ensure the oil which is amalgamated with the gas keeps the compressor running well and all the rubber O ring seals supple to prevent leaks. He also said Mercs with the EC button rarely have smelly systems as when the EC button is pressed is is on a timer hence it goes off after a set period-1 to prevent you breathing stale air for too long and 2 to prevent smells due to moisture/bacteria. If you can afford the slight extra fuel consumption he said Mercs with the EC button can/should be running the AC all the time.
I have always used my A/C all year round, never turn it off except in the SL
