Make sure the drain tube from the A/C is clear and free... if you don't see water on the ground after a long usage of the A/C, then it might be plugged up!
Smell is more often down to the system not working correctly.
First port of call is A/C specialist or even quick fit to check correct operation.
You certainly are trying for the 1000
try ALDI'S , they had some A/C freshener in last week, very cheap and they work
