Well I thought it was the MAF playing up, but after changing it for a used one that proved to be faulty,(once fitted would not tick over and kept cutting out) and having changed all filters it seemed to be running better. My old MAF runs the car fine until it warms up then starts chugging and smoking. Disconnect MAF and all fine. Now noticed I am getting a smell of diesel and on inspection the pump appears damp. Also there is a bolt missing from the inlet manifold.
My limited knowledge of injection engines, tells me that if the fuel system is not sealed properly then it throws out the sensors as they try to compensate, would this be the case here? Small leak on inlet side of fuel system causing the MAF to over compensate. I will be removing the inlet manifold soon and checking pipes are connected tight, so while I have the manifold off what would be the suggest check or replacement of seals/pipes etc?
