horgantrevor
- Jan 14, 2011
- w202 c43 & w210 E220 CDI estate w219 W221
How much did they cost?
yes
if you dont mind me asking what are you putting them on too is it a ML
and also how much ?....
have you a link to site
and i think a set would look great on my w202
Not cheap
How does having more pistons increase the stopping ability? Surely that is governed by the friction coefficient between the tyre and road surface.
I appreciate how it may affect brake pedal feel.
As this is a front brake mod only, as more force transfers to the front brakes might that not upset the brake balance and cause instability and possibly reduced stopping performance overall?
Also if the calliper now has a greater operating area does the master cylinder not need increasing in size to accommodate the greater fluid flow?
I thought Alx explained it perfectly. by having 12 pistons ( 6 x per pad) you exert a much more even pressure between the pad and the rotor. This means that the friction material on the pad is in much more uniform contact with the rotor resulting in greater resistance making the car stop quicker.
If you look at a 2 pot or 4 pot caliper set up then the center of the pad is in greater contact with the rotor than the outer edges so the braking performance is not as good as if pressure were being exerted equally accross the whole surface area of the pad. With a 2 or 4 pot caliper set up braking is best in the centre of the pad and decreases towards the outer edges.
But the brakes won't lock up immediately from, say 70mph, so the pad to disc friction comes into it as well.
Are the pads the same area as the originals?
If those disks are the same size as well then drilling holes in them reduces the friction material available hence the braking efficiency is reduced. Drilling the disks to improve cooling will only help if the current setup gets them so hot that they no longer work properly but I guess for road use that rarely happens?
Would also be interesting to know the weight compared to standard.
They do look lovely though
