Just thought I would share my experience as it might be usefull to some.
Well firstly, jesus the filters are stupidly expensive. I have paid £230 For just the Oil, fuel, cabin and 2 air filters at the dealers. I bought the oil from ECP, 10 litre (x2 5 litre) of Mobil 1 ESP 5W30 for £72.
This was my first time on this engine so I took my time with it. I changed the oil using oil suction method from the top which went fine. After taking out 8 litre of oil, I filled 0.5 litre of new oil and used pump again to suck it out to pickup any left over dirty oil.
Air, cabin and oil filters were an easy job, now the fuel filter on the other hand is definetly not.
The location of the fuel filter is just between the 2 air filters so pretty much on the top middle of the engine. Now the problem is, you also have a pipe going through on the right side of the fuel filter and the pipe has an small extention that is just placed on top of the filter and I think its been put there for no other purpose but to be a nuisance. Unfortunetly the pipe has to be moved out of the way and to do that you also have to open up other bits which is quite a pain in the bottoms.
So basically as I did not have the right tools to reach certain bits, I gave up on it and now will ask Terry from WG to do the fuel filter aswell when he does my gearbox service this friday.
