So , today i fixed .....
Howard
MB Club Veteran
Toad Hall
CLS 500 / A 150
My numberplate lights that stopped working yesterday .... :rolleyes:
Standard w124 problem , wires snap in the hinge as the boot is opened and closed a million times ....
Took the trim off , had a gander .... what do you know , it's been repaired before ( badly :mad: )
3 completely broken brown wires , one with a yellow trace , 1 completely broken grey with purple stripe wire , one partially broken grey with purple stripe and white dots wire ....
Interestingly , where it had been repaired before, the grey/purple wire ( with a bullet connector ) had been joined to the grey/purple/white dot wire and vice versa ..
Stripped them all back , wired them up correctly, and wrapped in spiragrip , and what do you know , as well as the number plate lights working properly now , the boot light works ( it hasn't for the last 5 years :rolleyes: ) ...
So treated it to a new 10w festoon bulb as a mark of respect ....
Job done , 1/2 hour ..... nice
BlackC55
Portsmouth, Hampshire.
E55K SL500 E300Hybrid E250X3 Viano C55 E450Cab A180 Smart 44 Brabus
Well done.
Did you use insulating tape?
There is available proper MB fabric tape and its far superior to insulating tape. I highly recomend it.
gbjeppm
Surrey
C207 E Coupe 350cdi, W166 ML 250 Cdi Sport, R171 SLK 350, Suzuki V Strom DL650
I love it when a plan comes together:D
If only all my dabbling ended up like that:eek:
OP
OP
Howard
Howard
MB Club Veteran
Toad Hall
CLS 500 / A 150
Hi Olly ,
No didn't use insulating tape , used a thing called spiragrip , its like a flat plastic spiral sheath that you wind on ....
Keeps the wires all together , and looks neater than insulation tape ... i know the fabric stuff you mean though ( sticks like s**t to a blanket ) ...
The wires through the hinge are in a plastic circular conduit ....
television
Hardcore MB Enthusiast
Dorset on South Coast
R230 SL500
Heat shrink sleeving is the best for joining when soldering the wires, the wires stay the same size.
Self amalgamating tape is also very good,, just stretch it as you wind it on and it all becomes one. (it is removable)
OP
OP
Howard
Howard
MB Club Veteran
Toad Hall
CLS 500 / A 150
Hi Malcolm ...
I didn't do anything as technical as soldering .... :eek:
Male and female bullet connectors are my friends .... ;)
