@Chris-S, how long did your FIT tariff take to set up?
Sadly, it’s not a great time of year for a new install in terms of sunshine is it. Ours produced 1.5kWh yesterday . We’ve seen over 30kWh on good days in summer.
Still, with your E7 setup, you’ll be saving straight away won’t you.
Not quite sure what you mean about the minimum discharge. Our engineer said that 0% is really 20% to help maintain the battery life. Do you mean yours doesn’t go lower than 5%?We were pretty lucky with the roof on this place. It’s cruciform in plan, and the main area is slightly west of south so gets good coverage. We have 10 panels on the main south face plus 2 more on the small south bit on the end, then 3 panels on the east and west facing sections, so we get some sun on some panels pretty much the entire time it’s above the horizon. Looking at the individual panel generation figures suggests we could maybe improve it a tiny bit by moving one or two of them, but not all that much.
Assuming the PW was discharged, it will give itself a little bit of a boost, particularly on cold nights. Is yours set with a 5% minimum discharge? Ours was at first, then after talking with them, they set it to 0 but we had some issues with it cycling between charge/discharge so set it back at 5%.
What latitude are you? We’re near Nottingham.
