some questions and problems.
LongR
well. since yesterday i own a s430 auto from 1999
i have some questions...
i checked satnav.. it is working radio is working aswell.
but when i pressed cd is says "no cd changer" why is that.. maybe different.. where to find changer.. where should it be??
also it says phone error.
is something not right or it just does not have changer,phone and tv
also one more problem is that a/c off have the liitle led on all the time.
it means it is off all the time right??
also it seems to blow the bit warmer air on the left side that it does on the driver side.
EC button means economy when pressed (red light on) it turns the a/c off. just think you dont have a phone or CD changer fitted !
Hi, CD Changer should be in the boot, passenger side. If the system is saying CD not found, then this is quite a common problem, the fibre optic system in the early cars is prone to failure. Pulling the fuse will reset it for a while but the problem will be back. In regards to the AC, the compressor itself maybe at fault. Hope this is of some help to you.
thankyou for the link.
did check.. looks like i dont have a cd changer and tv.
on the other hand where is ec button??
