PhilT
- Aug 10, 2013
- C63 AMG Saloon
As above there is something seriously wrong with the car so I will explain what its doing. Sorry its a long one! The car is a 2013 C63 Saloon with a V5 Eurocharged Remap.
It has 4 new tyres on which are Michelin Pilot Super Sports which where fitted in December & I would have a guess at the car has done 2000 miles if that since they were fitted.
Note this is even on a straight and worse going round bends. AND the Tyre pressure monitor has come on twice recently and I have checked pressures & reset them but it has come on again.
In s+ the traction light is coming on in 1st and 2nd seriously cutting the power even in the dry. It never used to do this, It used to be fine even in the dry
In s+ and sport mode turned on which normally lets a little bit of slip, The car is pulling all over the road like its on ice with 1000bhp in the dry (Seriously grabbing onto the steering wheel fighting to keep it straight). It never used to do this, All it used to do was like normal allow a tiny bit of slip but no wheel spin and the car would drive straight
It feels pretty dangerous to be honest and I always used to have fun abit round the bends but I tried it while it was like this once and it was not easy to control at all.
I have also noticed the front end seems like it was gone light & also the car even in comfort in the dry when it sets off in 2nd gear traction kicks in this is on a straight and worse when setting off on a bend.
I have put the right pressure in the tyres as advised in the fuel cap too. They are also standard tyre sizes for the 19" optional wheels.
I hope you can help as I have no clue what could be up with the car and I am normally pretty good with cars. I remember having a little bit of wheel spin on the yoko tyres and the car didnt feel as fast which I put down to needing new tyres and it has been worse like above since.
It was fine for 2.5 years since I have owned it from new (remap since new) till just before symptoms started before the tyre change.
This also maybe relevant, When it was on the yokos I had a blow out on the rear drivers side at only 20 mph and pulled over straight away which I admit was due to myself as I did not check the inside of the rear tyres which had both worn down to the canverse, Part of the tread came away from the tyre and flapped about in the wheel well. (This was over 1 year ago)
Also 2 weeks ago I took the car for a good drive and the tyre pressure monitor came up with check pressure, I was in the middle of no where so parked on a flat surface and all the tyres looked like they were inflated, the car drove fine for 1 hour then 5 minutes from home there was a lot of road noise and the car felt like the tyre was coming off so I pulled over straight away into a petrol station and the rear drivers tyre had gone completely flat! I tried to put air in and it wouldn't hold pressure. I swapped it to the spare and drove home and checked the wheel/tyre. The tyre was ripped which was because it was flat when I drove into the petrol station and there was a cut in part of the tread which may have been the cause for it going flat. I took the wheel to a wheel repair place and they took the tyre off to inspect the wheel which they said looked fine apart from the inner wheel did move slightly on the wheel weight machine but he said that wasn't enough to cause any problems. To be safe I bought a brand new rear wheel and tyre but I still have the problems.
