Sony Highlevel input connectors
KillerHERTZ
Administrator
Staff member
Cambs
SL63 AMG
Any ideas where I can get them?
No luck on eBay, local car audio place reckons he might be able to order some in, but cant confirm if they will be the correct ones... :doh:
Connector
That looks like a Molex connector - you could try RS components, they stock Molex.
I'm not sure which one it is, you'll need to measure it up and select the one nearest to it.
There is another option - I have a Sony surround sound system (in the house) which has similar 2 pin connectors which Sony will only supply for a huge amount of money, Maplin sell a remote control battery connector :
Battery Connectors : Battery Connectors : Maplin Electronics
You could try two of the female versions and force them in.
Hope this helps
Good idea, might take a look at them tomorrow and file them down to fit :)
Is the wire already attached thick enough for speaker cabling?
The Maplin connectors do have cables, should be large enough for speaker connections.
