Dieselman
Banned
- Jul 13, 2003
- Peugeot 403 Convertible
After there being a few threads relating to S/W switches being stuck in W I decided to play with mine.
After rocking the switch several times and feeling the box change ratios it then decided to stick in W mode.
Knowing there is a little plunger and then a switch I decided to have a look.
There's nothing dificult about this but it is a bit fiddly.
Remove the console
Armrest screws under bottom felt.
Unbolt the gear selector
Unclip the gear linkage
Undo bolts on reverse interlock. Note position set screw.
Unclip upper cover and push innards downwards using selector indicator unit. Park is the best selection for this procedure.
Lift switch unit out. Note peg that interfaces with switch unit.
Open selector switch case.
Refitting is reversal of removal.
I think someone posted that the dealers just fit a complete selector unit, parts cost about £250 + vat.
It takes about ten minutes to get apart, I actually took this apart twice so you could have the piccies. Hmm.
Remove the console
