Yep plenty of W203 saloons made down there, as I understand all the estates were made in germany though.Shows I know not a lot about mercs, just found a 'made in South Africa' sticker on drivers door pillar...
Whats the score? its first reg in July 2004.
Must have been a special then as AFAIK all w202s were made in DE. Check the VIN, that will tell you which factory.i heard my 202 was made in south africa.
I think plant 67 is Bremen. That's where my 202 estate was built. You should be able to tell by the letter in the VIN. A-E is Sindelfinden, F-H is Bremen.
I would suggest doing a few edits to post #7. Tooooo much detail.
Could end up in the wrong hands..........
All W202/203 (Saloon) were made in South Africa.
S202/203 were made in Bremen. I know.....I went there to collect mine even. Great trip and would do it again if buying new.
Mark Cosovich, the W123 obsessed guru swears S. African cars are better than the German versions. Far superior leather, sound deadening & a few other things which I can't remember at the moment.
I'd be a lot more concerned if Americans had built my Mercedes.
You are at best half right; as stated there are no W202s made anywhere other than DE.All W202/203 (Saloon) were made in South Africa.
All 203 (Saloon) were made in South Africa.
S203 were made in Bremen. I know.....I went there to collect mine even. Great trip and would do it again if buying new.
