Just add distilled water with it.What's wrong with the coolant from Merecedes?
quoted from Inside an F1 Engine - Racecar Engineering Note how small the water capacity is/was... obviously there various reasons why they got away with just 4 litres of water but one of them (and the reason why the m104 engine in my s124 has 9.5 litres coolant capacity) is because adding glycols to water reduces heat transferCurrently the V8 runs with around four litres of water in the entire cooling system, including the radiator. This is circulated at about 270 litres per minute by a small, high-revving impeller, which pumps the water out of the engine at 125degC. Water is still believed to be the best cooling medium and the engines run it with nothing more than the addition of a corrosion inhibitor.
