Madferrit
- Mar 29, 2005
- Location
- London, NW
- '06 B150SE, '99 E220 CDi, A160, Ferrari Mondial and a Smartee! Now Sold: G300 LWB (sadly missed)
Got this from another forum, and it seems to work well for me.
1.Type "about:config" into the address bar and hit return. Scroll down and look for the following four entries:
a) network.http.pipelining
b) network.http.proxy.pipelining
c) network.http.pipelining.maxrequests
d) browser.turbo.enabled
Normally the browser will make one request to a web page at a time. When you enable pipelining it will make several at once, which really speeds up page loading.
2. Alter the entries as follows (by double clicking each of the above four, will change its value,ie true becomes false and vice versa):
Set "network.http.pipelining" to "true"
Set "network.http.proxy.pipelining" to "true"
Set "network.http.pipelining.maxrequests" to some number like 30. This means it will make 30 requests at once.
Set "browser.turbo.enabled" to "true"
3. Lastly right-click anywhere and select New-> Integer. Name it "nglayout.initialpaint.delay" and set its value to "0". This value is the amount of time the browser waits before it acts on information it recieves.
If you're using a broadband connection you'll load pages MUCH faster now! :bannana:
