Speedometer conversion - W220
turboGT
Mercedes only!
Hi everyone,
I have a Mercedes W220 and it has both MPH and KM/HR readings.
However, I would like to convert the speedometer entirely in KM/HR.
Is there any way to do this?
Thank you for helping :)
The digital read out can be changed in the cluster settings from memory.
The actual physical face has much larger mph numbers than kph. If you buy a cluster from Germany the. It will have kph as the dominant larger text above mph.
Thanks for the replies :)
But if I change the cluster, will the mileage change as well?
You could get that reprogrammed.
