Muppetz
Reading another thread ref an indicated speed of 85mph on the motorway (and what that true speed would be..) got me thinking ... http://www.mbclub.co.uk/forums/showthread.php?t=54534
Surely manufacturers would always set speedometers to over estimate speeds, for 2 reasons :
1) So they can't be taken to court when you are caught doing 31 if your speedo says 30 (for example). ("It's the cars fault, it said I was only doing 30mph...) - They would need to build in some "margin of error" for this ?
2) If the speedo over reads, then does that mean that the miles completed over a period of time will also be over estimated ? If so does this mean that the mpg will appear slightly better than it should ? and also that services will happen slightly sooner than the should ?
i.e. if the speedo reads 100mph and I drive for an hour then the tripometer should also read 100 miles... If the speedo has been over estimating a real speed of 90mph then have I actually only done 90 miles ?
And therefore after 10,000 mile indicated have I only done 9,000 miles ?
So the manufacturers could claim better mpg, and have you in for service more often(or claim longer periods between services !)
