tjamesbo
- Jan 6, 2007
- Location
- Sutton Coldfield Midlands
- CLK430 ,Vito V6 sport ,Jaguar 2.5 X type ,W124's 1993 220TE , 1994 320TE ,Mastercraft X5
looking at wire crimpers and this was a spec.
I have some of these terminals
This trade quality Automatic 3 in 1 Wire Stripper and Crimper is suitable for both professional or DIY use. It allows the single motion stripping of wires/insulation and the crimping of insulated and non-insulated terminals.
It has a wire stripping range of 0.13 6.0mmì/10-24AWG. Perfect for stripping any wire within it's range, even the most delicate one's like telephone and network cabling.
It features alloy steel jaws which are hardened and tempered, with polypropelene with rubber non slip inserts handles.
Simply place wire in jaws and squeeze and the wire will be stripped automatically.
Specifications:
Made from quality steel
Handles are sleeved with polypropelene with rubber non slip inserts
An adjustable stop is incorporated to give uniform lengths of stripped wire
Wire cutter incorporated also
Cuts and strips 10 - 24 AWG/0.13-6.0mmì
Suitable for copper and aluminium wire
Crimps - insulted terminals - 10-22 awg
Crimps - non insulated terminals - 4-22 awg
Crimps - ignition terminals 7-8mm
Specifications:
