What do people recommend for a deep-shine/high gloss spray-on wax for gloss black alloy wheels? I like to spray something on after a weekly wash and I’m finding sonax quick detailer doesn’t really cut it with these wheels.
ideally you need something that is more heat resistant.
have you not considered coating your wheels??? most wheel coatings are about the same cost as a litre of detailer etc and will last around 12months/24mnths depending on brand type
also Wowo's crystal sealant is great stuff, and you'll get about 6mnths on your wheels with one coat
ah, in that case, stacking products on top of the C5 will mask the coating and not allow it to work very well.
Pretty sure you can stack GTECH Evo on the coating or use C2V3 as a topper... saying that any sio2 based product should work well too
I've never read about not over-coating? What I have just done is re-apply Poorboys wheel sealant and have got the deep-gloss look I was after (again!).
I see, its not going to harm the coating, it will just mask the cleaning properties of the C5. However poorboys may not last as long if its doesn't bond directly to the coating.#
If your after an easier product then look into Sio2 based sealants, or toppers as they will work better than the wax matey
